1 - 2 of 2 Posts
i have an 87... i believe its got the air density meter if im not mistaken. How pricey/ extensive would a mass air conversion be?
u mean "speed density". there are a few differnt ways to do it.. one is a PITA and is expensive and one is fairly easy and affordable..
the first is to buy s conversion kit..uausally about 3-6 hundred and that comes with
-whole ecu harness (u have to take the dash out to get it out and back in) and if u are lucky it will have the same plugs as your car...(mine didnt)
-computer (ecu)
-mass air meter(uausally stock)
or u can peice it together yourself and get better parts...
go on craigslist or ebay or here and find a set of 24lb injectors and a good mass air meter.
then go to a junkyard or ebay or craigslist and get a computer (make sure it is an A9L or A9P for a manual or just an A9P for an AOD
then get this eBay Motors: 86-88 EFI Ford Mustang 5.0 Mass Air Conversion Harness (item 380010510313 end time Apr-04-08 05:55:22 PDT)
it is easy to install with some wireing expiernce/soldering
1 - 2 of 2 Posts
