Hey guys. I have an 01 GT that's been siting for almost a 1 year and 3 months. October 2016 was the last time I ran it and it was to drive it up my driveway and park it in the garage. The oil pan was leaking like crazy and the intake manifold pipe cracked and and the heater hose blew off (beautiful coolant shower).
So the car was parked ever since and sitting in the garage. Last November I started working on it: Dropped the K member, changed the oil pan gasket, new OEM engine mounts, new Koni STR's, new front lower control arms, and new Stabilizer bar end links and sway bar bushings.
Anyways, I filled it up with distilled water today in hopes of starting her up. I noticed water (no coolant since it all leaked out - engine was not running) was leaking from on top of the driver side bell housing. I tried retracing my steps from my intake manifold install (OEM ford manifold with Fel Pro gaskets) and could not find a leak from:
- Heater core hoses
- Intake manifold (all bolts torqued to factory specs)
- Water pump bolts tight
Now the car was supported by an engine support beam for about 1 1/2 months by the bolts that come out of the heads (Ford said these were the sturdiest bolts to use). I checked the cylinder heads and can't find any leaks (wouldn't think it would leak out of there without it running).
Any ideas guys? If you are wondering as to why the hell the guy let the motor hang that long on the support beam... I babysit my 1 year old and my wife is 7 months pregnant.. So you dad's out there can probably understand the lack of availability we have for our hobbies!
Thanks for helping out guys. :smile2:
BTW - If you have any questions or want/need tips and tricks on dropping the K member, feel free to ask!
- Heater core hoses
