Hey everyone, been a stressful passed 2/3 months. It all started when my car overheated, brought it to a shop and turns out I had a cracked temperature housing. Quick fix and never had any overheating issues again.
Once it got colder out I began using the heat and it would blow cold air. Brought it to the shop about twice.First time got a radiator flush and when i drove it off the lot heat worked like never before. After 20 minutes of driving when I got home heat started giving in strangely and once I was on my driveway it was dripping from the outside on my driveway. All the coolant was gone within an hour. Brought it back to my mechanic and he added water to check for any leaks, pressure tested it and no leaks at all. Told me to keep the water in there to check and see how the heat kept up and for almost a week a half it was perfect.
Then got the water flushed and replaced with coolant since I finally thought somehow the problem was solved since it was working great.
Yesterday after driving almost all day and heat working fine during the evening i saw a bit of steam coming from hood and the heat completely went cold. After checking my coolant reservoir it was empty again.
After waking up in the morning and driving to work after a few minutes of driving temperature pointed to overheating so I stopped at walmart and added 2 gallons of coolant since it was empty and overheating seemed to have stopped. Let the engine run for a bit but no signs of coolant leakage
Does anyone have any advice or suggestions?
Also side note my mechanic specifically said when changing my oil about 2 weeks ago that it didn’t seem different in consistency therefore he believes it’s not the head gaskets
I can also post pictures of coolant splattered around my engine bay
