Hi guys!
Im kinda new here and unfortunatelly my first post is about an issue.
I had a leaking radiator, so I bought a new Mushimoto from americanmuscle I've installed it myself bleed the system and when i took it for a ride few miles later coolant started pooring out of the reservor cap! not just leaking...
So for some reason it builds pressure and it pushed the coolant from the cap.
I did some research but im still confused. Brough it to my mecahninc, we put new thermostat, and new cap. After 5-6 miles drive when the engine temp goes to "normal" it starts pouring out. However car does not overheat, fan works, AC works, as long as i still have coolant ...ofcourse.
Now I wonder what else could it be ?! Faulty/cloged radiator ? Blown head gasket? water pump?
It does not have white around the oil cap, wich will point to a headgasket.
I have no radiator cap to see what's going inside the radiator.
Also I have electric water pump wich my mechanic have never seen before...
I know I know, what kind of mechanic right..
So any ideas about troubleshooting are welcome...
