1 - 8 of 8 Posts
I put on the explorer upper/lower combo and some other things to my 95, but im blowing white smoke. My question is the egr hole directly in the center of the lower mainfold that does not connect to the upper. as yall probally know that. I goofed up and did not plug that hole. So could that be pushing coolant through my lower to make it push out whie smoke?
The head gaskets are good i replaced them when i put my new heads on and all are torked down to spect.
did you re-use the head bolts that were on there origionaly or did you buy new ones?
The Razor's Edge
small note - blue smoke oil
black smoke - grease or carb build up
for the most part.
how much white smoke and has your fluid level went down....how long has it been happing?
coolant is getting in somewhere. If it didn't do that before the swap you might have screwed up one of the gaskets either head or intake.
1 - 8 of 8 Posts
