I have a friend trying to run loc wire gasket and an o-ringed block. He can't get it to seal around the water ports. I haven't seen any of the stuff but he says the head is milled out for the loc wire gasket and he has o-rings in the block. I have never heard of running both. Can you do that or will the combo cause you to not be able to compress the gasket enough to seal the water ports? He has steal heads and stock head bolts tq'ed to 100 ft lbs.
Thanks
Thanks
