I have converted quite a few stangs over, from foxes to 07's. There is a lot of misinformation and myths out there about E85.
No, you dont have to change lines or tank.
Yes, you will need a higher capacity fuel pump.
Yes, one step larger injectors is a good idea.
Average increase in demand is around 19% n/a.
Remember, nearly all of our cars currently run on E10. That means your fuel system is already handled ethanol in it.
Yes, there are two different grades of E85, E70 and E85, and all kinds of blends in between as tanks with some E85 in them get E70 dumped in the fall and vice versa in the spring. I highly recommend a tester be carried in the car. You,ll need two tunes, E85 and E70. A switch chip can handle it.
