I just took a look at the on3 turbo kit, what would you recommend for me to get in the package? I have a stock motor with basic bolt ons with only 30k miles on it. I was looking into buying new A-arms and I have some coilovers already installed. Realistically I wouldn't want to spend anything over 2700 if possible. Also thanks for all the help so far!
---------- Post added at 08:07 PM ---------- Previous post was at 08:02 PM ----------
Sorry, I'm not too experienced in modding nor do I know much about parts but I'm assuming its a fuel pump basically?
---------- Post added at 08:08 PM ---------- Previous post was at 08:07 PM ----------
@blownsang
Alright, so for the on3 turno kit. You would opt for the slot style mag with the maf flange pre welded on. As far as turbo. I personally went with the on3 67bb with the billet wheel originally. I loved the thing. Although the internet jockies recommend replacing the blow off valve and wastegate from on3 stuff to tial or turbosmart units. (I did with tial, I have also seen people out there run the on3 stuff without issues)
The items I would recommend changing are the V band clamps (I will post a link to the V band clamps shortly)
The suspension required would either be UPR tubular K member and A arms. Or the ones from on3... which I believe are UPR anyway.
Aside from that. You will need injectors and a pump. I would either do a drop in focus pump and a boost a pump. Or a 340 pump with the fuel basket chopped up a little. (I think I still have my modified stock basket laying around somewhere)
I provided the info, but I would strongly suggest if you are new to wrenching that you go with a supercharger over a turbo.
The turbo will make significantly more power per pound of boost, but it is significantly more involved in the install and ironing the bugs out of it. A supercharger is more of a bolt it on, tune it and go operation. The kinks with the blower come in the form of belt alignment, and just make sure your cold side pipes/silicon couplers are T bolted together well. You have one vacuum line to your blow off valve/bypass and that's it. Simple.
