1 - 3 of 3 Posts
ok got a new shift light and one wire gose to the tach wire, dose anyone know witch wire is the tach wire and what color it is , second i just got a new wideband set up" inovate lc-1" and i need to install the bung, where in the pipe should it be located, should it be next to the #1 o2 sensor in the left bank, will it get correct readings there?:confused:
You need a tach adapter to get the proper signal for the tach, unless it's specifically designed for the Coil On Plug setup.
1 - 3 of 3 Posts
