1 - 16 of 16 Posts
Does anyone know where i can get a forged crate engine for my 1997 mustang gt that has at least 325 horsepower for at the most $5,000 and the compression isn't too high? An engine that is already assembled so i can just drop it in.
Thanks,
Mike
The UPS guy
sean hyland has 4.6 engines...there expensive..IMO its worth it though...they have a ton of options you can add to them as well...they have sohc 300hp 350hp and 400hp and dohc 350hp 500hp 600hp to i think...check them out...seanhylandmotorsport
Your not going to find a crate 4.6 engine with 325 horsepower for under 5000. You would have to swap a 5.4 in there but even at that it probably wouldnt be forged. A forged crate engine isnt going to be cheap at all. The only way your going to be able to get a forged 4.6 with 325hp is going to be you putting it together yourself.
The UPS guy
yea if u peice to together you could probably do it...IMO the shm is worth it...its brand new...has a ton of options..and im pretty sure it was warranty....
I would but i don't have 10 grand to spend on it.
wowowow those are some engines
The UPS guy
what on sean hyland??? if thats whats your talking about then yes they are so nice...i wanted to get the 400hp dohc but my dad explained to me how he thought they werent worth it...dude just buy a nice short block and take your time on it...if it takes a few years then so be it...it wont kill you with money or time...you wont have to come up with 5k all at once either and you can research andfind out wyhats good and whats not...
Jlaw said it right. Time and patience. Do it right and you wont be picking up pieces off the track. Get a said of pi heads get em worked and add some cams and valves. Then buy a built short block and there you go. Stage 2 h/c on a built short block should net around 325. Plus youll be ready for lots of nitrous.
The UPS guy
yup yup...my dad just finished a 351c for his uncles 71 cougar....took him a year...he worked on it like once a month when he had some time...just take ur time...you wont have to shell out a ton of money all at once...research research research!!!!
why not get a 4.6 dohc from like a mustang junkyard and rebuild it if it needs it
You can get a 4.6 4v from a Lincoln mark 8
Heads and cams are gonna run you like 2500 or so. Bottom end is gonna be another 2500 or so. Then you have to assemble it all
The crate motor im looking at is built from the crank up. It costs like 6300 and its ready to go. I just wanna know if its enough to handle 11 pounds of boost.
1 - 16 of 16 Posts
