1 - 4 of 4 Posts
I have a 2014 Mustang with the spoiler that has the back up camera inside of it. I want to put the California Special spoiler on my car. I've seen people talk about removing the spoiler previously, so that's not my issue. My issue is what to do with the camera. I am for sure not sacrificing the camera for the new spoiler. I've seen previous threads about retrofitting it the bumper or the gas cap emblem, but I'd prefer to attach it to the underside of the CS spoiler. I've only seen one other forum where a person didn't use an aftermarket camera, but still used the stock camera and attached it to the underside of a spoiler, but that was the GT500 spoiler. I don't even know all the details to how he did it and he doesn't seem to respond anyways. Obviously I'd be keeping the camera in the current housing that it is in. I am not referring to the trapezoid shaped thing that is visible when you look at the spoiler. I am referring to what is inside there and keeping it protected. There are already 4 holes but I'll be drilling 4 additional holes because the CS spoiler is a pedestal spoiler and it needs 8 holes. It seems that one of the pedestals will cover one of the existing holes that is already there for camera wire. I'll be detaching the camera fishing the wire up through the pedestal and across the spoiler. Once the wire is in the middle of the spoiler than I will drill a hole on the bottom side for the wire to come out or I will have already drilled it. I will reattach the camera but that's where my issue is. It seems that I will need some kind of trough shaped thing that the camera can sit in. Then that trough shaped thing can be screwed/mounted some how the bottom side of the spoiler. The trough shaped thing will obviously be positioned parallel to the car. (Trough is rectangular shaped) There are 2 shorter sides of the trough, so the side that is closest to the rear will be cut out or something, that way the camera can see. I just don't know where to acquire this trough shaped thing and how to not break it because holes need to be drilled so that screws can be put in. I'm not familiar with 3D printing at all, so I hope that's not my only option. Can anybody think of anything I can use that can be mounted to the underside of the spoiler that will keep the camera nice and secure? Or does anybody have any better ideas to attach it to the spoiler? Or any good places to relocate the camera? Anything helps, thank you.
This may help some... but not much: Has anyone retrofitted a back-up cam on a GT/CS with the navigation package? - Page 2 - Ford Mustang Forum
You can almost assuredly remove the stock trapezoidal portion from your stock spoiler, and then flip the housing 180 degrees. Once that is done, flip camera orientation 180 degrees as well, so that is it back to original orientation, but the housing is flipped. You can then likely notch out a portion of the GT/CS spoiler to use your stock mounting piece. I would suggest rivets, rather than screws since backup cameras are stolen quite frequently (unless you screw from the top through the spoiler from the inside, which could be a pain in the butt.
You'll need to make a hole for the wire, as you mentioned, likely between the two pedestal bolts on whichever side is closest to the stock wiring hole. Then you'll need to run the wire all through the spoiler which could be a pain.
Thank you for the reply. But the GT/CS spoiler is not thick enough to accommodate for a big enough hole for the housing.
---------- Post added at 01:48 PM ---------- Previous post was at 01:46 PM ----------
But thank you for the ideas of the rivets. That's a good idea.
1 - 4 of 4 Posts
