I've searched mm but haven't found anyone with the exact same problem as me. It's a problem with my 2002 gt.
After a cold start, usually it feels like it has no power in 1st, or 2nd, but after it warms up it drives like normal.
When in any gear if the rpm's are below 2000 and I press even a little on the gas (to accelerate, cruising speed throttle position is fine) the car begins to cut out, my shifter shakes, and it can be solved by shifting down.
Although it doesn't seem like that big of a deal, I just don't want it to happen. Any explanations or suggestions? I can post a video of what it does if that would help.
Car has yellow top injectors(idk if these are stock), o/r h-pipe with only 2 o2 sensors, hasn't been tuned for it.
