1 - 3 of 3 Posts
i have a 02 mustang gt. 4.6. runs like crap at idle but at higher rpms its fine. check engine light says cylinder 4 misfire detected. changed plug. coil and boot. still same problem. did a compression check and its bout 50 psi lower then the other cylinders. any helpp?
Head Unicorn
not good at all....... It could be any number of things. broken valve spring, bent valve, blown head gasket, cracked head, broken rings......... bad though, whichever it is.
1 - 3 of 3 Posts
