1 - 6 of 6 Posts
Why not have a Fox?
So the only dash lights that work are my blinkers, and warning lights. None of the guage lights work, and the climate controls dont light up. The po said he took the dash out to look for the problem but they came on so he put the dash back in. If someone knows what the problem is or can give me a link to another thread that be great! Im sure this is a common Q so i apologize for the repeat. And im not a very good electrition so bare with me. Im thinking its probly the dimmer switch. Thanks!!!
well could be a coupe of things but first take a look at your harness that runs to the back of the headlight switch those connecters are notorious for cracking,make sure all of the wires are pressed into the switch,a bad dimmer switch is another common failure start with that and get back to us
Why not have a Fox?
nope just the headlight switch on the instrument cluster housing
Hallelujah! just hope thats where the problem is. Ill check it out in the next few days and get back with results. Thanks!
1 - 6 of 6 Posts
