1 - 20 of 32 Posts
I got a kit from hidmasters, I'm assuming there all generally the same, take some pics ill tell you which plugs into what
Making Bad Decisions
Well I have been using this video and its helping a lot.
Main thing no is I want to make sure I put the pos and neg stuff right.
I know these are supposed to be plug and play for the most part.
but I am a big noob when it comes to electronics for cars.
well I think the wires from the ballasts to the lights are color coded right? then theres the power source right to the battery, then it's just the ground wires, I just unscrewed those screws on metal like right above the headlights and attached the grounds/screw em back in. last thing is the 3 pronged plug that 3 wires go into, which plugs into the back of the headlight plug, basically it.... does that make sense? lol
okay so i pretty much know what to do.
only question I have is if i turn them on with out the ballast mounted somewhere will it matter?
like if they are just sitting on the fender but the grounds are in right.
no that won't matter, the only thing that there's an actual order to is the 3 prong plug, when I did mine I had them backwards causing the highs and lows to be mixed up, so if that happens swap two of the wires until it works
turn the fogs on, and see if they turn on/stay on either way you have the wires, try the middle one too
---------- Post added at 08:40 PM ---------- Previous post was at 08:01 PM ----------
get it?
Discussion Starter · #12 ·
Okay so I got it all figured out and I will do a quick write up to probably.
So anyone who needs Help installing your HIDs from DDM I can help you now. Haha
Also will add some pics here soon too.
quick question. you get the 35 or 55 watt set up....and whats the difference? also, what bulb type is for the headlights nd foglights...gonna order a couple sets for my car
Discussion Starter · #20 ·
35W 6000K for both headlights and fogs.
55W is brighter, and it would be overkill for stock housings.
Headlights are 9007 and fogs are 893.
1 - 20 of 32 Posts
