1 - 10 of 10 Posts
Ok i picked up a 83 t-top fox and have rewired it for Efi. Does this sound like a decent motor build? Horsepower potential?
My motor selection is a 89 302
Crane POWERMAX 2040 cam (ecam equivalent)
performer edelbrock heads shaved 30
explorer intake
65mm tb
BBK LT headers
catless h
373 gears
I have a similar setup except I have a 70mm throttle body and a b cam with the same heads except mine aren't milled.
I put down 293rwhp and 311 foot pounds of torque.
I highly suggest you get an Anderson N41 cam or a custom grind. The cam is gonna hold you back a bunch.
Is your intake stock or ported?
Sent from my galaxy s II
intake is untouched.
Maybe ill pick another lower up to port match. As of right now the motor is together and to be installed this weekend.
I was hopeful it would produce at least 300.
Stangbannger: is yours dyno tuned or what did you do for tuning?
Mine has an SCT chip/dyno tune.
You need that intake ported if you want any hope of being close to 300. Mine is nicely ported, and puts down good torque numbers down low considering my peaky b-cam.
you need a better cam bud.
Discussion Starter #9
Where can this Anderson cam be bought? Or should i just get a custom grind?
Anderson cam can be bought from Andersons website... Just Google Anderson motorsports. You'll see it.
A custom grind cam you can buy from Mike Jones, Chris Straub, Ed Curtis etc. Any of them will do a great job.
1 - 10 of 10 Posts
