1 - 3 of 3 Posts
When degreeing (including adj. lifter) is it best to degree with 1 follower, then install the rest? Or degree with all installed? Either way, the cam has to be pulled to retrieve the adj. adjuster right?
Degree it with the one follower installed on the intake valve/lobe you are working with. Once the degreeing is done, everything is torqued down, install the rest of the followers. You do not have to pull the cam to get the followers out. Just turn the motor over til the follower you are trying to remove is resting on th base circle of th cam and pop them/it out with a large flat head. If there is any resistance, you are probably not on the base circle and could do some damage if you just try to muscle them out.
Ok thanks! Also, should I start on the #1, degree there and move to #6? Then once degreed reinstall? Shouldn;t be too bad. Waiting on iron tensionsers to show, then I'm doing this. HOPING it works... First timer here!
1 - 3 of 3 Posts
