1 - 20 of 23 Posts
why did/do I think it was 1/2 and 5/8
You just re route the hoses to loop instead of hooking up to the copper pipes with a 5/8 to 3/4 fitting to splice the two hoses
WRONG! thats the lazy way fool! you rip the hard lines that run up to the firewall out of the lower intake all together, cap the feed at the water pump, go to lowes get an adapter to shove the temp sensor in the hole where you pulled the hard lines out. Mustank showed me this it cleaned up alot of junk under my hood
Skirt Chasing Philanderer
+1
But they do sell bypass kits that merely reroute it from the HC.
does the mustangs heater pipe have the swiveled threads on it? I know my trucks heater pipes you had to turn all as one piece, if thats the case, the fuel rails and intake get in the way. Some may not want that hassle
na you can do it with a wrench, its awkward as **** but its possible, i did mine with the intake out though
Out of a ton of research i found this way to be the best... taking out the whole rail and...
nice enginuity, powerder coat it and it would really clean it up
1 - 20 of 23 Posts
