21 - 40 of 42 Posts
Discussion Starter · #22 ·
It's been a while and we've made some progress here and there. We had to have the floor replaced once again after further inspection found that the person who did it before royally ****ed it all up and actually never fully cut out the old floor. I need to get the images but we have the fuse block installed and the new A/C - Heating unit installed under the dash.
The brakes on the front have been upgraded from drum to disk. Replaced all of the front suspension parts. The springs were a massive headache.
The engine should be going in with the next month or two. The C4 was rebuilt as well.
Some of the random parts.
Discussion Starter · #23 ·
Finally got it back on all fours. Suspension 100% done.
The dog has been helping.
Sneak peak at the dakota digital gauges.
Custom lines we had to make for the brakes, rebuilt the distribution block and added a proportioning valve for the new disk brakes on it. Used a rebuilt booster from West Coast Classic Cougar.
Another image of the brake lines and setup with the addition of the borgeson power steering box.
Wiring going out. The rear of the car is finished.
Dash going in.
New Antenna.
2002 Mustang
Wow most people I believe would have settled with the original condition, doing a few touch ups of course, but what you did is inspiring. Good work!
Discussion Starter · #31 ·
Thank you! It's been a rough road.
The package tray and the speakers are now installed and tested. They sound great!
Discussion Starter · #40 ·
Got both doors finished off. Finishes the interior off having these done. The last interior piece to go is the steering wheel.
Not much of an update other than an image of the drivers side door. We had to measure and figure out where the mirror adjustment knob would fit through the door panel since it didn't come with a precut or measured place for it. We got so focused on getting that figured out that we completed it without putting the moisture barrier behind it so we had to take it all back off and redo it.
Interior is done. Finished. Finally.
21 - 40 of 42 Posts
