1 - 11 of 11 Posts
I have a 2002 gt with a few bolt on's an just put a diablosport predator on it an when i crank it cold it misses then stumbles on take off an straightins up at a bit warmer temperature. Anyone know whats goin on? or how to fix?
How many miles are on it? Bet its just getting tired and when it heats up the piston swell a tad and like wise the cylinder restoring compreshion...
mm's nitrous mod
just install the tune? it may take a little bit for car to get used to it. the prameters have changed and will change few characteristics of the car.
!FACEPLATED!
My car does it after it sits for a while. Started after I put the LTs on. I just let it warm up a little bit and its fine
June 2010 ROTM
Diablo has their own forum. I"d go there and post up.
Honestly, I'm not aware of a car having to "get used to the new tune" Its just a computer. It should work fine after a tune install, imho.
Have you put the stock tune back in and see if anything changes? I'd do that first.
mm's nitrous mod
computers have to learn when things change, it has to adjust parameters to suit driving style. lots of vehicles will drive different if parameters change like if tune is changed or battery unplugged for a while, etc.
Computers have a KAM (keep alive memory). This learns and remembers things like the idle, as well as your driving style, for shift points and shift firmness.
+1
+2
Now that I think of it after my car sat for a month it did the same...it studdered like a retard when it first started but soon straightened up
Discussion Starter · #11 ·
thanks guys, the car has set a while but i drove it for about 2 days then out the tuner on it..my truck does the crazy stuff for a few hours when the programmers took off or put back on.. maybe its just the computer adjusting
1 - 11 of 11 Posts
