1 - 13 of 13 Posts
im trying to decide what diff. i wanna get.. input would be awesome thanks.. im looking between the Detroit locker in 31 spline and the DETROIT TRUETRAC
I'm gettng the truetrac cuz I've heard people having stories that thier tires screech at turns with the locker
i been trying to find info on that.. i like the locker just for the fact that it puts 100% to both wheel.. but im still trying to find info on both
i also like these for the fact no clutch to burn up like on a posi.. i burnt mine with my 315's thats the only thing i can think of.. and both are "suppose" to be almost indestructible
Do you hit up the strip a lot? Don't really know a lot about either but I'd think the trutrac would be better for everyday driving. I think I am safe to assume the locker is the better choice for drag racing though?
no not really but.. i wanna build it to where i dont ever have to worrie about it.. thats why im doin 31 spline moser axles. i got a trick flow diff. cover. nd a set of ford racing 3.73's. nd also have a set of ford 4.10's but im planing on using the 3.73 cause its a daily driver.... now just trying to find the diff. i want to use
hmmm...Well i wish I could help you out but I just don't know enough about the diff. if the truetrac is supposedly indestructible as well I'd go for that one. Is it worth having a locker in a daily driver? hopefully someone else will chime in with locker experience
i just ordered the trutrac last night from summit i thought the same thing about the locker
:rockon
I have the D-locker. If you're car is not 90% drag then I'd go with the trutrac. The locker is definately a different bread and your driving habits will have to change on the street. Not for a faint hearted. But aside from a spool its the best insurance you'll ever buy. I'm going on over 200+ 6800rpm dumps on slicks and it hasn't skipped a beat.
-Mark
Discussion Starter #11
nice.. and i ordered the trutrac now i need to find out what weight oil to use and if it needs an additive
If It doesn't have a clutch then it doesn't need a additive but I'm not too sure on that
Friction modifier is added to clutch pack style LSD units.
1 - 13 of 13 Posts
