1 - 20 of 46 Posts
I installed my drag radials today and went to the track looking for glory. Instead, I found only dissapointment. My car ran worse with the DR's then it did w/o. I ran a 13.9 last week, and a best of 14.0 this week. What's the deal? I was launching at about 3200rpm and it bogged and jumped. What do you launch your DR's at??
Im basically stock, Cat-back and JLT.
N/A 4v Guru
Launch harder. Launch higher and higher till they spin on launch and back it back a little. You should be able to launch alot higher than that with the DR's
You will have to play around with tire pressure, you will want just a slight bit of spin off the line to keep the RPM.s up it's all trial and error till you find the right combination, you'll find the right combo and will be pleased with the results.
I would, but I fear that I might break something.
I was running 17psi in the rear, And they were hooking extremely well. Too good I guess. Do you usually dump the clutch or ride it a bit?
Dump it but I would think 3200 rpm should be plenty I would play around with tire pressure. Ask aroud the track to see what the others with a similar setup have and what works for them.
N/A 4v Guru
The whole point is to not bog realy bad and for the most part you just want a little spin. If you are launching at 3200 and bogging below that rpm when you launch you are hurting yourself. You can have too low tire pressure as well as too high. so like cet2kill said, you gotta play with pressure as well as launch revs
Too much traction will hurt you.
Ya.. maybe when we have super small motors that cant fight against your D'R's when they hook up with no spin... but we dont have 4cylinders.. we ride horses. l0l
+1 lol
and it bogged and jumped..
i would say thats your problem. u need to feather your clutch or take a risk and launch at a higher rpm range.
u might be getting a better 60 foot time when u were on street tires. i could see how bogging it down would slow your et by a little bit.
it bogged and jumped.... Too much traction off the line.
Then why did the car bog?
you definitely don't want to bog a mod motor, especially if you have stock gears. depending on what drag radials you have, you could prolly launch that thing really high!
you wanna find the rpm where you get a slight 2-3 rotation tire spin then hook.
1 - 20 of 46 Posts
