1 - 9 of 9 Posts
Ive posted about this before and couldn't get the answers I was looking for so I decided ill try again. id like to delete my abs pump. I know ppl have done it by just removing it and adding brake line but I cant find pics or directions anywhere. I know some lines need to use a T fitting to connect 3 lines but im not sure which ones. any help would be great thanks. Pics would be ideal
I'd use the billet delete block if it is still available.
Dat guy
The ckassifieds mod motor mustangs on facebook, a guy sells delete plates.
---------- Post added at 05:36 PM ---------- Previous post was at 05:21 PM ----------
https://m.facebook.com/infinitemachineconcepts
90$ shipped, they do it custom too i believe, let me know how it works out if you get it, been thinking bout that delete myself but nervous about it.
I might have to end up buying one but I'm looking for someone who's just spliced in line. I know it's been done
im not a member on there. if I join will I have to get a certain number of post before I can post in there classifieds?
King Trashmouth
I did it without the block. It was actually really easy.
First tag all the lines with what they are and where they go.
Remove the pump, cut all the fittings off the lines. Install new SAE 3/16" double flare fittings on all the lines.
Now just connect them with a pair of T fittings. MC front T's into the LF/RF lines, MC rear T's into the RR/LR lines. Tuck it however you want.
Bam, you're done.
1 - 9 of 9 Posts
