1 - 15 of 15 Posts
window was working yesterday, tried to roll up the driver window today and nothing, its all the way down
I can hear a kind of clicking sound when i push the down button, but nothing with up
Passenger side works fine
bad motor? if so how hard are these to replace yourself?
thanks
Was it hot out where you are today? My window would not go down today after I got out of work. After about an hour in some shade, it worked again. These window motors are notorious for getting sticky when its warm out. When they cool off they start working again.
yeah it was pretty hot, ive had it in the garage now for a while, but still no luck
thinking either its the motor or regulator
I've also heard of people taking off the door panel and tapping the motor with a hammer. That might get it working if it doesn't on its own by the morning.
That's what i did, and it worked.
My truck did the same and so does my mustang occasionally, both fords of similar era.
Truck finally died and I took the motor out, and now I just push it up and down with my hand.
Mustang will probably fail completely soon as it doesn't work more often than it does.
If it fails you can buy a motor/regulator from ebay for 40 bucks, and they are pretty good. Ive had mine for 2 years now. And its pretty easy to install.
I just had a similar problem a few days ago, except my window was stuck in the up position. I tried the door slam trick, the hammer tap trick, the let it cool down and try again in the morning trick, nothing worked. I tested the switch by holding the switch down at night with my gauges on, and my gauges dimmed, so my switch was working. So, I was convinced it was the motor. Then it rained hard the next day and voila, it magically started working again. I have no idea what happened, since it rolled down and up fine after that and didn't sound like it had gotten stuck or anything
1 - 15 of 15 Posts
