1 - 9 of 9 Posts
I got my wideband air/fuel kit in today. This may just be a dumb question. lol but better safe then sorry.. The bung has a smaller ridge on one side then the other. just barely not much smaller at all. Does it matter which side is welded? just curious. cause the instructions doesn't really say. I would assume the side that doesnt have the ridge is the side u want to weld against the pipe. Thanks. I will have all 4 of my new gauges installed within the week.. I will be sure to post a pic of inside the car once im finished.
Discussion Starter · #2 ·
this isn't the wideband kit I have. mine is digital.. but the bung looks the same.
That gauge would barely move. Why would it sweep to 20
lol, that isn't my gauge.. I just used that pic to reference the bung.. My gauge is digital
Are your rear O2s off? If so you could use one of those bungs.
If not people use the driver's side at a 3 or 9 o'clock position. So it doesnt get wet, and because its easier to get too.
I would do it after the first O2 sensor, so it doesnt interfere with the O2 sensors reading. Just my opinion.
I believe the side that has the ridge goes into the exhaust tube, it’ll prevent the bung from being moved around while being welded
ahhh.. i didnt think of that.. that does make sense tho.. thanks
a.k.a. Racecougar
Wiser by the Minute
I would put it as close to the header as possible. I put it on the collector for my long tubes at about the 10 oclock position. I would put it at 10 or 2 oclock position if I were you.
1 - 9 of 9 Posts
