1 - 2 of 2 Posts
im trying to connect the door trigger wire for my 3105 viper alarm and from what i read there negative so i tried connecting the green alarm wire - on the green/yellow in the A pillar and alarm doesnt sound. i tried probing the maplight for a wire that goes + when door opens but all lit my test light up with door closed. i watched an install on motorz website and they say connect violet+ from alarm to green /yellow in pillar.im confused if the 2006 mustang has negative door trigger how can i get it to work using violet+ on triggers? appreciate any help.
Zip's half naked helper
What they are using is the dome light power wire to trigger the alarm using the positive trigger wire.
The correct way to wire it up would be to use the green negative trigger, and diode isolate each negative trigger from each door at the smart junction box in the passenger kick panel. I don't remember which two wires they are off the top of my head.
1 - 2 of 2 Posts
