Well I figured it out and yes it makes all the sense in the world. The back attachment to the factory 3 piece window attachment should be attached so it has no pivot point. The front doesn't pivot or pull on the window except down. The rear one relies on the glue to hold the bracket horizontal and not pivot at the attach point but that creates a ton of shear/stress on the glue and it'll eventually fail. I'll post a pic of the little bolt solution whenever I can find a set of small bolts locally and install them. For right now my E6000 glue is curing. Its a 24 hour cure time but the tube says up to 72 hours for full strength bond so I'm going to let it sit for a week to be sure.
