You dont need to match the stock size to put them on the stock rimIs there not a tire like Nitto or BFG G-Force that makes a street drag radial tire for the stock 17 inch rims. Its a 2005 with 235/55/17 on it.![]()
For the drag strip i'm gonna get the brenspeed take off rims and M/T et streets for 650 but i wanted a good tire for the street that gets better traction than the perilli pnero zero'sDo you want a sticky tire that you can daily drive? Or are you looking to only use these on the track with limited street use?
So what would be a good rim to move up too cause I'm getting a s/cIf you are going with a supercharger, then it will be a good idea to upgrade to wider rims and of course, a wider tire because there really aren't any tires that will have any traction that will fit on the stock 17x8 rim and still have good street manners.
k thxReally any style that you like in a staggered setup.
I would recommend an 18x9 up front and 18x10 out back. The front width can vary some, but I would get the rears in at least 10 inches wide.
with those rims i could go 255/45/18 nitto 555r on front and 275/40/18 on the rear right?Really any style that you like in a staggered setup.
I don't understand your question.Do they make the same MT ET streets 275/40 for 18 " wheels?
