1 - 7 of 7 Posts
Picking up a set of 05 16in wheels tonight for 100 and going to Prolly put the 255 mt street et's. On them... called mt and they said id have a bit of sidewalk bulge but it'd work just fine
Yes, I am your Daddy
Make sure they fit right. I tried some drags that were supposed to fit, but they didnt clear my brakes.
I would recommend getting something bigger than 255 if possible, 275s at least.
The 255 is all they make in the 16 for the mts and ill slap a spacer in there if I have clearance problems should be pretty close though
Personally I would have gotten Weld Prostars with MT ET streets 275/60/15, but it sounds like you got a great deal. I'd be worried about the backspacing.
Not wanting to spend that much and I plan on driving 25 min to and from the track on the wheels and backspacing should be close and if not ill throw a spacer in
Ok so a pair of 15in wheels off a newedge have a backspacing of around 5inches so these would stick out further then what I have on there now correct?
1 - 7 of 7 Posts
