so in late april I'm going to install my eibach pro kit tokico shocks and UPR camber kit. Do I need anything else? So far I have rear spring isolators. I need the front spring isolators, offset rack and pinion bushings. could I install the springs without the spring isolators? I was thinking it will drop my car a hair lower.
For the driveline I have a FFRP aluminum driveshaft and I'm changing my tranny fluid with syncromax royal purple. I know there's a keyway slot in the yoke and that has to be lined up. and when I bolt the driveshaft in does it have to be bolted in one way or can it bolt upside down?
