1 - 8 of 8 Posts
Here goes.
First, just tuned for the gears, 93octane, raise rev limiter (6400), disable trac control. (stock airbox, no time to install CAI)
No problem, everything fine.
Second, Install CAI, adjust tune to call for 90mm Steeda CAI.
Get a few P061B (torque control management bla bla bla), limp mode, read, clear , retighten all clamps to be sure, reload tune a few times.
Finally everything falls into place, no more P061B DTC.
Now, a couple times i get P0175 & P0172,System rich bank 1 & 2, no limp mode.
When cold (and not getting on it at all), when warm, geting on it and not.
Not that often, but enough to warrant this post.
Anybody else experience this after CAI install?
Golf Pencil Kawk Juggler
Sounds like a tune issue honestly.
Idk much about the steeda CAI though. Just jlt
its a tune issue, get it worked out!
Did you buy it new or used? The Steeda CAI has been 90mm for the longest time but when they first did them they were 80mm. If you bought a used 80mm and you got a tune for the 90mm you will have all kinds of problems. You would need to either get the right tuning done or upgrade to the 90mm maf housing.
Actually thats a great point. Would not have thought of that.
Sounds like you had that issue.
Brand new, out of the box.
Will get a custom tune (Bama or Brenspeed).
I don't feel it needs a dyno tune for the few mods I have.
Once I get SC, LTs, the works, it will be a different story (plans, plans!).
Just throwing that out there in case someone had the same issues.
Thanks for the responses.
Same issue I’m having without sleeve insert tree bank 1 2 lien not enough fuel put sleeve in has po61b code first issue was told to put sleeve in no goes in limp mode as soon as you get on it
1 - 8 of 8 Posts
