1 - 13 of 13 Posts
is there like a discount for being a member on modded mustangs for that xcal3? also. do i need a maf? if so what size. power pipe? im just trying to get the most out of this p1sc and intercooler. i got 42lb injectors and im getting the fuel pump. any other goodies i should get to get the most out of it? should i get all this before the tune to make it more accurate. Thanks bro.
Contact Joe at trick tuners (i believe his screen name is trick tuner) for the xcal3...he will give you a great price on it. Yes you need a MAF...ATI Pro-M is what i recommend. You will not need a power pipe.
Do not get a MAFia, i ran one on my old setup hated it. Jaxdawg bought my old setup, but also used my ATI Pro-M MAF (i never used it) when he got it tuned...he picked up 20 whp with basically the same car.
does he sell that too or where would be the best place for it? so F the power pipe then!
90 mm?
Yes f the power pipe for your goals.
They do sell MAF's but if your on a budget you can look at the classifieds on corral.net
aight cool, i think their site is down or something. it wouldnt let me on there earlier. 80 mm or 90 mm or what? and is that all else that i should get in order to aid the supercharger to work the best and safely?
Corral.net can be a very slow loading website...it times out all the time.
If you get the ATI, the most you will need is a 80mm....75mm will work just fine.
aight cool... thanks alot bro. youve been a big help! ill let you know if i come up with any more questions. im sure i have alot more coming. thanks again!! if you think of anything else that will help support the SC then feel free to let me know.
Discussion Starter #11
hey how do yall feel about a 160 degree thermostat? i heard from some local guy that putting the supercharger on there would heat everything up and to put a performance thermostat on there. what ya think. only 28 bucks.
Discussion Starter #13
yeah i went with the 180. after doing a few searches i saw that.
1 - 13 of 13 Posts
