yes i learned that the hard way... spun 1st and 2nd.if u dont have tires and u dump the clutch, ur gunna spin ur tail off for an hour
Dumping the clutch = popping the clutch... At least where I come from, it is.o ok i thought tht meant pop the clutch so i'm guessin ther the same thing
:stickpoke........slip the clutch...give it more or less gas pending tire spin
yea wats slippin tha clutch?
.Wikipedia said:Slipping the clutch
Slipping the clutch (sometimes referred to as feathering the clutch) is a term used by automotive enthusiasts to describe when the driver alternately applies and releases the clutch to achieve some movement of the car. It's called slipping because the clutch plate will slip against the flywheel surface when such an action is performed. Slipping the clutch is known to be hard on the clutch surface due to the sliding friction created.
Drivers can frequently be observed slipping the clutch when they are trying to stay stationary on a hill without using neutral and the brake. They apply the clutch to climb a bit, then release to roll back, then apply again, etc. so that the car stays in about the same place. The alternative to this technique of staying stationary on a hill would be to put the vehicle in neutral and apply the brake.
Slipping the clutch is a popular term in drag racing culture and is done when launching a car, usually in a drag race. Some contend that slipping the clutch is the best way to launch a front-wheel drive (FWD) car as it prevents Torque steering that many FWD cars experience when too much power is put to the front wheels.
