1 - 20 of 45 Posts
Finally have an appointment for my car to be tuned after the blower install. I always enjoy reading these types of threads so I figured I would make one. What kind of numbers should I expect to see on thursday?
Paxton 1200sl (3.6pulley)
39lb injectors
Cxracing 4core
Powerpipe
Kurgan toker pump
Stock maf and mafia
Tialq
75mm tb and plenum
Id like to see 375rwhp.
Super Moderator
Whos tuning? with the stock pulley Ide guess.
385
401
Super Moderator
Never heard of them, But none the less enjoy cause it will be like getting a whole new car.
~340-350rwhp.
I'd run a smaller pulley, like a 3.0. I don't think it'll make a lot of boost. Maybe 6psi
~340-350rwhp.
Ehh, thats what im worried about..
Do you hsve to get a retune when you swap pulleys?
I would. Don't want to risk anything. Usually the maf can compensate for ~2psi maybe 3psi at most, but I would re tune. Id bring a 3.2 and 3.0 pulley with you and run a 107.38" belt
~340-350rwhp.
+1. I'd say you'll need atleast a 3.33 to to come close to 370's. The Novi 1200 specs for max rpm and cfm are very similar to a Vortech V1 S trim. Try finding a 3.25. That should work well.
Torchin tires...
I have almost the same stuff, only a vortech and stock plenum, 3.5 pulley on 8 psi and made 347 on 93 octane
Why I said that. I have a cx 4 core. 2.87 pulley and power pipe. Made 11psi by 6000rpm. A 3.12 pulley will make ~9psi with the cx 4 core
Discussion Starter · #12 ·
Hmm, maybe I should buy a pulley wait until it gets here and reschedule..
Overnight ship it...
Definitely 3.12. You can always shift early if you make to much boost. But you definitely won't. And use a 107.38" gates micro v belt. Or a 107.0" dayco. Gates part number k061073 dayco part number 5061070.
Discussion Starter · #16 ·
Awesome. Thanksfor the help.
Discussion Starter · #17 ·
Superchargersonline doesnt let me select over night.. Any other suggestions?
Google it, I'm sure a place on amazon will ship it overnight.
Lethal perf might...
Its about time man! Goodluck! Definetly get a smaller pulley like they said above.
Super Moderator
More then likely your tuner will have a spare or new pulley.
1 - 20 of 45 Posts
