1 - 12 of 12 Posts
as the title says..
will it fit?
is there a kit to make it fit if it doesnt??
MM's Orangest
I don't think it will. And the cost of the swap would be right at or more than the cost of a centri.
well ive found the eaton for 325 with intlet and t/b.. what else would be needed? i mean im not about to buy some "C' heads..
MM's Orangest
This is everything for a C headed car to do the swap. :D You asked for it.
2r3z6312baa - Crank pulley /Harmonic Balancer
f1az6378a - washer for balancer
f5rz6a340b - bolt for balancer
2r3z6312ba - Supercharger Crank drive pulley
2r3z10153ca - Bracket that replaces stk. alt. on 99-01 Cobra’s and 03/04 Mach 1’s (Comes w/ pulley below if bought used)
yw7z8678aa - pulley for above bracket
2r3z6b209bc - Pulley bridge assembly for S.C. (If bought new it comes with the bridge, 2 idlers and tensioner)
(8678B) Idler pulley,timing cover pass. side
yw7z8678aa - pulley on drivers side of timing cover
(6D080) Timing cover (if bought new, it comes w/ pulley on drivers side and tensioner)
s5az6700a - timing cover seal
(10A313) Upper alternator bracket
(10153) Lower alternator bracket
(10346) Alternator
1U2Z-14S411-TA Electrical connector (alt. to harmness )
(6B209A) Tensioner on timing cover
2r3z8260ab - Radiator hose
2r3z8a593ab - Radiator hose
2r3z8k576aa - Radiator hose
2r3z8548aa - Water cross over pipe
(6881) Cobra oil cooler adapter
(6A642) Cobra Oil cooler
2r3z9002aa - Cobra fuel tank (optional)
2r3z9h307ab - Cobra fuel pump (optional)
2r3z6f066aa - Eaton supercharger
2r3z9424bb - Lower intake
(6K775) Garrett factory intercooler
3U2Z-14S411-SSA IAT2 sensor connector
2r3z9n491ca - Intercooler hard lines that hug the block (If bought new, it comes w/ part # 9l443c)
(9N491A) Intercooler hard lines that come from the h/e
3r3z9l443aa - Intercooler line that goes from the i/c adapter to i/c res.
2r3z9l443ba - Intercooler line that goes from the i/c adapter to the hard lines that hug the block
2r3z9l443ca - Intercooler line that goes from the hard line against the block to i/c pump(included w/ the hard line that hugs the block if purchased new)
2r3z9l443da - Intercooler line that goes from hard line to hard line
2r3z9l443ea - Intercooler line that goes from hard line from h/e to i/c pump
2r3z9l443fa - Intercooler line that goes from hard line and connects to h/e
2r3z9l443ga - Intercooler line that goes from hard line and connects to h/e
f8yz8501aa - Ford / Bosche water pump for intercooler
2r3z8n500ac - Intercooler pump bracket
2r3z8k226aa - Factory heat exchanger
2r3z8a193aa - Heat exchanger mounting bracket
2r3z8c386aa - 2each bracket clamps for h/e
(9N491B) Lower manifold to intercooler water adapter
2r3z9a589ca - Plenum
(9B659) Intake tube from maf to t/b.
(9F715) IAC valve
2r3z9f593ba - Injectors
(6F089) Boost bypass actuator
2r3z9a825aa - Cruise control cable
2r3z9a758aa - Throttle cable
(9728) Throttle and cruise control cable mounting bracket
1l3z12b579aa - MAF
xw4z9d475ab - EGR valve
2r3z9d477ad - EGR tube
(6C324) PCV tubing
(9F479) Sensor on the back of the S/C
(9J432) Bracket for vacuum stuff on left side of the S/C
(9H465) Vacuum stuff
(9J459) Vacuum stuff
(9J460) Vacuum stuff
(9E498) Hose's or tube cluster of connectors for the vacuum parts above
e83z9f670a IAC gasket
2r3z6020aa - Timing cover gasket LH side
2r3z6020ba -Timing cover gasket middle
2r3z6020ca - Timing cover gasket RH side
2r3z9h486aa - Lower intake to S.C. gasket
2r3z9l437bb - Plenum to S/C gasket
e6az9d476b - EGR gasket
2r3z3490aa - Power steering resevoir bracket.
I/C resivoir tank
i/c pigtail
S/C 8 rib belt
inner acc. belt.
n804178s309 - (8) Nuts for plenum, coolant crossover and pulley bridge can be picked up at local auto parts store in help section.
n805164437 - (1) Bolt for pulley cage to timing cover.
n808102s437 - bolt that is used on the idlers and pulleys. Only need if you buy parts seperately. You will need a total of at least 6 of these.
n808920s437 - Pulley bridge bolts
n606677-s36 (4) Bolts to bolt the bracket clamps to the h/e bracket
N605909s437 - (4) bolts for the upper alt. bracket
n807274s437 (1) lower alt. bracket to alt bolt
n811313s431 (4) studs to bolt plenum to s/c
w506404s437 (10) i/c to s/c bolts
nevermind all that ^.... all you need is this....
(10346) Alternator
(9F715) IAC valve
1l3z12b579aa - MAF
(6C324) PCV tubing
I/C resivoir tank
i/c pigtail
S/C 8 rib belt
inner acc. belt.
ur kidding right?? :sorry
Oh and sweet told me to tell you "**** you". lol.
lmfao.... but sweet loves me:D i think :sorry
well i guess the thought of that was a bust:( and too think i was alomost gonna boost this car too :sorry
MM's Orangest
Oh and if anyone wants to do a Whipple on a C headed car you just replace the Eaton in that list with the Whipple :D
mm's nitrous mod
is is possible, not as of yet. there are plans out for b-head guys that been looking to do this. the last time i seen the CAD design, there was no provision for a heat exchanger as of yet because of clearances, so if it comes out you will be limited on boost pressure.
Discussion Starter · #12 ·
*sniff sniff* you let me down :sorry
just kidding.. its cool.. i found a good deal on a eaton so i figured id see what all else i needed
1 - 12 of 12 Posts
