1 - 3 of 3 Posts
My GT 07 stopped working (I crank and it breathes a little and the en it shuts down) and the culprit is the harness in the middle of the ecu (the throttle body is all crazy and make noises).
The harness did go bad when they were fixing the ac and moved the lines and created a bad connection in this harness. The harness looks this way because the car was in a crash. I bought it semirepaired and the car was running just fine. It gave me trouble when they moved the lines installing the new ac condenser.
I will try to find a broken line or a bad connection in the harness but I want to ask if there is a place where I can buy this harness so I just can plug and play.
Sent from my iPhone using Tapatalk
file:///C:/Users/Shirley/Downloads/connectorcatalog.pdf
This might help ID the part number. You can cross check the pn with the index at the end. Might help you source one if you have the pn.
1 - 3 of 3 Posts
