I’m not quite following, it needs a new pats transponder antenna around the ignition cylinder? That can be swapped by itself if that’s the case.
My ignition was ripped out of my 03 and i cant get it to start. I have a wrecked 98 gt. I'm told the ecu will work from the 98 in an 03. Is this correct? I'm also told it would be easier to just pull the steering column assembly and swap that outI’m not quite following, it needs a new pats transponder antenna around the ignition cylinder? That can be swapped by itself if that’s the case.
I have the cluster and yes I have 03 keyNo because pats is in the cluster. Do you still have the key from the 03?
But how do I get the original key to fir I. A new cylinderNo because pats is in the cluster. Do you still have the key from the 03?
HowYou can rekey another cylinder for your key.
