1 - 4 of 4 Posts
I changed out my lifters and when I pulled the valve cover I had to force the EGR module to the firewall VS removing it. It was loose to a degree and moved out of the way. Now I have an exhaust leak there and its driving me nuts.
If I delete will I get a trouble light or code?
How is it done? Plug the manifold port with a plate, cap the vac port and plug the exhause maniford hole?
What do I do with the sensor? Let the wire hang?
Where can I get the EGR tube, Ford?
MM's Resident Ricer
what part of the EGR valve is leaking?
Fairly sure its at the bottom near the exhaust manifold.
The tube has play down there. Visually it looks fine.
The sound is like a tapping. I thought wristpin or lifter (theye are btrand new NAPA replacements)
My buddy fired up his XR4Ti to show what a bad lifter sounded like. It was different, we went for a ride and he said he was 100% it was an exhaust leak.
Guy really knows 2.3s but he's a turbo/hotrodder guy. Didn't have an extra tube for me to swap in.
At this point I am debating delete or fix. (new tube)
An EGR valve itself at NAPA is $159 :eek:
"Plug the manifold port with a plate, cap the vac port and plug the exhause maniford hole?"
thats what most people do from what i hear . It will throw a code . but doesn't do much else.
some people say it helps others argue that !?
1 - 4 of 4 Posts
