What is the benefit of the EGR removal? Is this something that should be done on a DD? Current goals are to remain N/A with track useage in the future. Thanks for the info.
I really wish i would have found the site sooner than I had. Cuz I would have deleted my egr, cuz i got a code and had to buy some sensor for the egr costed like 75 bucks. I am definatley deleting mine when I do my windstar also.Another thing is generally a LOT of cars have codes pop up related to the EGR valve. either it goes bad or a vac line. its cheaper to delete the EGR valve and never worry about it rather then replace it
EGR recirculates exhaust gases back to your intake to reburn them.(emissions). You probably wont notice a butt difference. But your engine will.What is the benefit of the EGR removal? Is this something that should be done on a DD? Current goals are to remain N/A with track useage in the future. Thanks for the info.
Yes. It reduces burn temperature which reduces NOx formation.The EGR isnt just to reburn exhaust gas, its to cool the combustion chamber to reduce NOX, one of the pollutants produced when the combustion chamber reaches 2500+ degrees.
