1 - 10 of 10 Posts
so my electric fan is not working on my 03 gt and i cant figure out the problem, checked the fuses, replaced the fan and the CCRM and it still doesnt come on, any ideas?
EDIT: after looking through the diagrams in the haynes, the only thing left it seems to be is the PCM power relay, cant find any info about it though or where its located or anything
Are you talking about the radiator electric fan? Is it overheating because of this? Just want to make sure that you know it's not supposed to always be running but rather it only runs when needed.
yes the radiator fan, it doesnt turn on when i turn the AC on which it should, it will only overheat when i sit there and let it idle for a long period of time. it started getting warm last time and letting antifreeze out of the cap and that's when i noticed the fan not working
should be under the hood in the fuse block there.
the diagrams for the one under the hood show the relays, are for wipers, starter motor and fog lights
that fuse is good, tested it with a meter to make sure, im gonna test everything tomorrow with my multimeter and figure out what the problem is. finally getting to put all my electrical training to the test haha
ended up going back through all the fuses and stuff. when i replaced the fan and ccrm something made the 60A fuse blow so i replaced that and it seems to be working now.
so I have the same problem and was wondering if it should be a 50A or a 60A because mine blows a 50A after about 15 min of driving with the A/C ON
what ever ford calls for is what you should use. If you put a fuse thats rated at a higher amperage than whats called for you stand a good chance of seriously fubaring stuff up. Its at that amperage for a reason
1 - 10 of 10 Posts
