1 - 9 of 9 Posts
I already made a block off plate as well as removing the egr valve but my only problem is that I have my check engine on is there any way to fool the computer into thinking the egr is connected?
Get a quarter horse tuner. Turn it off or set settings so its not a factor. Other than that you can't.
Did you use the turbo coupe computer?
I did. LA3. Used everything from a wrecked '88 turbocoupe. I do get all of the codes for the egr when I scan, but t g e engine light isn't on.
The light is probably burnt out from the cluster or there is probably not even a bulb on it
The lb3 in my truck also doesn't throw a code with not egr
1 - 9 of 9 Posts
