1 - 10 of 10 Posts
I'm putting together a motor and go to turn it over by hand.
It wont turn over. So i tear it down until only the crank, rods, and pistons should have any resistance to spinning.
Still wont spin by hand. The transmission is hooked up but not in gear and the camshafts will spin but the crank wont complete a rotation.
Could the transmission be causing the engine to bind? Because I'm not sure what else it could be.
If it's an AT then I'd unbolt the flexplate and try again to rule out the trans. If it's manual have someone else push the clutch pedal while you try turning the motor.
I think I found out the problem.
I think the flywheel is coming in contact with the bellhousing and causing the engine to halt.
I haven't had the chance to pull the transmission today but will be doing that asap
Super Moderator
your building a motor with the transmission still attached?
  • Like
Reactions: Woodman
No, it wasn't originally attached but it's been long periods of time between each step.
I built the motor up then attached the transmission.
Long period of no work.
Go to turn it over by hand and it locks up
So it was for sure the transmission but I didnt see any nicks or gouges to indicate the flywheel was coming in contact with the bell housing. Ideas?
Super Moderator
If your binding unhook the transmission to start.
I need more info Do you have timing stuff hooked up?
Discussion Starter #10 (Edited)
The timing was not hooked up when I tried spinning it but when i unhooked the transmission, the engine was able to spin again.
How do I rotate the transmission? I'm hesitant to put a pair of pliers on the input shaft
Edit: I put a pair of pliers on the shaft and it spun easily and freely. So this brings me back to the bell housing.
If anyone else has other ideas I'm all ears
It ended up being the clutch fork hitting the pressure plate because the ball stud was too long
1 - 10 of 10 Posts
