1 - 20 of 28 Posts
hey guys getting ready buy the stroker kit and want to make sure i do this right. I just picked up a set of TFS twisted wedge 205cc fully CNC'd and want to build around 10.5:1 compression. I have hurd the problems some people have with putting dome pistons with those heads. hurd the valves in the pistons. I want to make sure this will work. pretty sure the heads have 64cc champers. not positive though.
well you kinda have to be positive about the cc to get an accurate compression
yes i know this, where would the part number be on the head? i bought them new at a swap meet, so no f'n paper work or anything.
just looked it up and looks like they are 65cc champers. i have the TFS twisted wedge 205 CNC heads. pretty sure they are 65cc.
huh i have been looking around and with 64cc chambers im looking at around 9.5-9.8. which was lower than i wanted. also thought about decking my block if i had to, but then i would be in the same position of piston-valve clearence
i would go have them cc'd at a machine shop and make sure. unless you just want a "pretty sure" build.
Discussion Starter · #8 · (Edited)
yeah i can cc them at school.
so if they are 65cc combustion champers, how can i get 10.5:1 compression without getting piston-valve clash.
mainly i just want to make sure i wont have clash before i order a rotating assembly and have it not work.
Discussion Starter · #11 ·
yes, was trying avoid that to keep cost down. im kinda on a budget with this and dont have much room to play.
Discussion Starter · #12 ·
ok they have 65cc chambers. im looking at running .550 lift or so max. i want to run as close to 10.5:1 compression. how can i achieve that and not have piston-valve clash
well the total lift doesn't effect PTV clearance because the piston is far away from TDC when max lift is achieved, it's all dependant on the valve events and cam timing.
you will have to check PTV clearance no matter what, if you're that strung up for cash just cut your own valve reliefs...
its simple, just fly cut the pistons, its not hard at all, prob run you 100 bucks at a machine shop. Simple answer to a simple problem
If your going for a budget stroker then thats what your going to get, like E3sean said its usally a flat top. with them heads make sure you get the right reliefs in the pistons there are certain kits that are designed for them heads. usally around 1600ish depending how good you want to get.
Discussion Starter · #18 ·
alright, just looking at the graphs and tables it shows those 65cc chambers with flat top pistons only making 9.2-9.8:1. is there a calculation for every .010" taken off of the head to show how much compression gain i would see?
your not going to gain much, the more you take of the more your gonna run into PVC problems. just make sure what you take of you double check the PVC you usally want around .0080 clearance from piston to valve
Discussion Starter · #20 ·
ok thanks, i am going to check the clearance with flat tops and then go from there when i get to that point. but still what is the calculation for how much i mill off the head? if i have the clearance i will mill the head because i am goign to want that extra compression. unless you guys think that flat tops and 65cc chambers will get me to 10.5:1 even if the charts say it will only be 9.5 or so
1 - 20 of 28 Posts
