I have a 96 gt 5 speed and got the following codes:
P1443 and P0174
P1443 Probable cause:
- Failed EVAP pressure sensor
- Blocked hose between purge valve and FTP sensor
- EVAP purge valve stuck closed
I have had this problem before, and replaced the EVAP pressure sensor a few months ago, the CEL went away. Now its back, could it be the same problem or what else could it be?
P0174 Probable cause:
- If bank one and two are set together suspect a fuel pressure condition or MAF sensor fault.
- Failed H02S21 ( heated oxygen sensor - Bank 2 Sensor 1)
- Ignition misfire condition
- Fuel injector problem
- Engine mechanical condition
I have no idea about this one. The O2 sensors were replaced last spring.
If anyone has had these problems, please let me know on how to fix them.
Thanks!
P1443 and P0174
Thanks!
