1 - 9 of 9 Posts
I just read some codes with a code reader and got P1504 and P0350. Does anyone know what these are?
Discussion Starter · #2 ·
I got:
P1504 - Ignition Coil Primary/Secondary Circuit Malfunction
P0350 - Intake Air Control circuit malfunction
Is this related to the supercharger or is it something that needs replacing?
Doc
check to see if the coil is loose.
if it's not loose it probably needs to be replaced.
it's an easy swap.
2 screws and an electrical connection is all it is.
it's an easy swap.
Isn't there a separate coil for each cylinder?
1 - 9 of 9 Posts
