1 - 9 of 9 Posts
I have a 99 gt and its a daily driver. I want to give it an engine rebuild, and i dont know exactly where to buy a kit or what exactly to buy. I do want to eventually supercharge or something like that, but not for a while, so i need something thats good for daily driver and possibly for modifications in future.. Thanks!
☼ny
All u would need for some mild boost supercharging would be forged rods n pistons(around 9:1 compression?). MMR has some good deals on good quality parts. Have the heads cleaned up and checked at a machine shop and reuse or send em out to get ported if u wanna spend a lil more. Finally get some mild supercharger cams from CMS or MHS and upgraded springs. U can use those without boost for now.
That would be my budget DD build.
If u have around 11 grand, then do what I did...reused block bored .020 over, 5.0 stroker kit, TFS heads, CMS stage 3 cams, Eddy intake, Upgraded fuel system, 4:10 gears. Mine's a N/A motor though. nitrous later
  • Like
Reactions: echastain88
BYAHHHH!
Modmax for parts.
If you go to MMR only buy the parts DO NOT have then "build" you an engine. But afford them if all at possible.
☼ny
Modmax for parts.
If you go to MMR only buy the parts. DO NOT have them "build" you an engine. But avoid them if at all possible.
Is that what u meant?
BYAHHHH!
Yup lol it was on my phone. They will **** your engine up worse than that paragraph I wrote!
US Air Force (retired)
This is not true. A stock motor will handle 9 psi of boost for a long time. I have personally run my motor at the power in my signature for about 90,000 miles. If you want more than I have then yes, you need forged internals or cams. I'm running at SAE 380 rwhp. Cams give you an addition 50 rwhp without blowing up the motor.
☼ny
But he wants to refresh his motor anyway, so why not get some forged stuff for peace of mind? I had close to 120k miles on my motor when I decided to mess with it. She ran great, but you couldn't make me supercharge that. What I said is definitely not considering limitations of a stock motor, but it's just what I would do if I was on a small budget.
1 - 9 of 9 Posts
