My first engine (302) removal. Two questions, please:
The manual says to "disconnect the engine suppport insulators at the brackets on the frame underbody." Does this mean the 4 bolts attaching the engine support assembly to the block, or the long pivot bolts just above the rubber isolator pads on the brackets? Or something else? Seems like the 4 bolts makes sense, as the engine would still be supported solidly until lifted out.
The manual says, after disconnecting the flywheel from the converter (C4), "secure the converter assembly in the housing." how would I go about doing this?
Thanks much - pretty scary undertaking the first time around.
