1 - 6 of 6 Posts
ok i have a 1979 mercury capri (mustang) and i just bought a new k member for it the k member is installed but the motor mounts are wrong placement and the 5.0 302 wont sit on the solid motor mounts from the placement. im thinking of just modding the motor mounts or just creating my own? and should i put in a truck 9" or a junyard 9" i can change the gears easily.
switch the mounts from one side to the other
ok switched mounts around dint work cause they are identical.... the k member was meant for a 5.0 and im very angry now cause the engine stoped running.
so are you putting in a 5.0 or the I6 that you tlk about in your sig
1 - 6 of 6 Posts
