1 - 2 of 2 Posts
I floored my mustang 02 GT.. noticed smoke coming out of the hood. I took it home, never over heated, and saw that a coolant hose had come undone from the intake manifold. After reconnecting, I noticed a ticking noise. I drove the car and it eventually stalled and killed electrical power. After a few minutes the car would start. But it started running or idling rougher. I towed it home. After trouble shooting I found that if I disconnect one of the fuel injectors electrical connector, the ticking goes away. So i ordered new injectors, replaced still same noise. Its the 3rd injector on the driver side Any ideas as to what is the issue ? Thanks.
Check codes and do a compression test on all cylinders.
1 - 2 of 2 Posts
