1 - 1 of 1 Posts
Alright I'm at my wits end. My mustang has the famous erratic idle. It revs up and down. Somdtimes it'll stick at 1500 rpm. I'll turn it off then back on or restart it and it'll idle better for a while. It's throwing codes 81, 82, and 95. I've replaced the IAC, the TAB/TAD, fuel pump, fuel pressure regulator, EGR Valve and sensor, cleaned the throttle body, replaced the plugs. The TPS is set at .98 and timing set at 10 degrees.
I've looked for vacuum leaks can't seem to find any. Used both the propane test and the carb cleaner test.
HELP!
1 - 1 of 1 Posts
